How hard is it to swap tail shafts in 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2012, 03:07 PM
I am trying to fix the transmission in my '86 Suburbon 4wd. I have an' 88 Chevy car in the garage with a 700R4 but tail shafts are different lengths. How hard would it be to swap shafts or change things arround to make it work?
Old 06-18-2012, 06:49 PM
you will have to totally dis assemble trans to swap them
Old 06-18-2012, 09:38 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Yep and while it is apart you may as well install the rebuild kit..I had to do that on my th400..
Sam
Old 06-19-2012, 02:13 PM
Well if I'm going to do all that I may as well just rebuild the one thats in there. I might have one to swap out of an other 4wd into mine.
700r4 Tail Shaft fit a t-350 ? monk250 Transmission - Rearend 4 05-12-2009 08:53 PM
700r4 output shafts stuvand Transmission - Rearend 2 05-15-2008 07:12 PM
T-5 tail shafts bluestang67 Transmission - Rearend 9 03-22-2007 06:37 PM
700r4 tail swap crossfire84 Transmission - Rearend 4 06-04-2005 12:20 PM
Can you swap tail shafts on TH350s? briwill Transmission - Rearend 5 12-11-2002 09:36 PM
