How to hook up a 700r4 TV cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 06:29 PM
How do you hook up a 700r4 kickdown cable??
Old 10-19-2010, 07:23 PM
Cape Cod Bob's Avatar
http://www.purplesagetradingpost.com...o/700R4p1.html
Maybe here,
Old 10-19-2010, 08:05 PM
Crosley's Avatar
Wiki Edits: 1659
the 700 trans has a TV cable, it is not a kick down cable.
The Throttle Valve cable must be properly hooked up and in operation for the trans to shift correctly
Old 10-20-2010, 08:45 PM
I dont have a q jet i have a edelbrock
Old 10-21-2010, 06:45 AM
SSedan64's Avatar
You'll need one of these.
http://www.summitracing.com/parts/SUM-700203/
There are several brackets that will work with the TV cable.
http://www.summitracing.com/parts/PFS-52126/?rtype=10
http://www.summitracing.com/parts/SUM-G1414/ with this http://www.summitracing.com/parts/SPE-2429/
http://www.summitracing.com/parts/EDL-8036/
TV Brackets & TV Geometry Correctors here also>> http://www.transmissioncenter.org/70...#T%20V%20Cable
Old 10-21-2010, 08:25 AM
dmx6's Avatar
Try here-www.bowtieoverdrives.com
That is where I got my stuff and info.
Old 10-21-2010, 12:05 PM
For some reason I expected those to be more expensive. I think i've been going to the wrong places haha
Old 10-21-2010, 09:29 PM
SSedan64's Avatar
The BTO kit is costly, if you want to be shocked check out Bowler's.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
700r4 TV cable? runn141 Transmission - Rearend 1 02-09-2009 12:43 AM
TV cable on 700r4 and 4l60e eatonde Transmission - Rearend 2 07-31-2008 10:44 AM
700R4 - TV cable tension problem wont allow WOT AussieModder Transmission - Rearend 4 07-02-2006 02:47 AM
Need help adjusting 700r4 tv cable 85irocss Transmission - Rearend 5 06-18-2002 10:40 AM
