how to hook up my tachometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2011, 10:10 AM
JLBpontiac350's Avatar
85' grand prix,th200M,chev305
hello, im trying to hook up a tach (super tach 2 cheap from autozone) i figured out where to run the black(negitive) and white(lighting) but not sure where i should run the red(power) and green (negitive on the distrubutor) wires. im not sure where i should run the power wire. so please fill me in on that. and the green wire says it needs to go to the negitive side of the dtstributor. i havnt a clue what the negitive side of the distrubtor is. i looked at one video where the coil was no attached to the distrubtor. i belive mine is. i have the distributor with (what i belive is the coil?) in the middle on the top. its little box looking thing. please help me out guys i wanna hook it before i gotta go to work tonight. thanks!
JLB
Old 05-03-2011, 10:43 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Run the Red wire to a switched hot in your fuse panel.
The Green wire goes to the disturber look on the cap it will read Tac over where the wires connect to the dist.
Rich
Old 05-03-2011, 11:03 AM
it dosnt say tach anywhere tha i can see. i know i have to splice into a wire.
all wires come from a small box on the driver side of the dis. that sasys dis. battery. theres on thick red wire thats leads off to somewhere else. and 3 small wires that go from that box to the bottom of the dis. thers 2 black wires and an orange wire.
Old 05-03-2011, 11:07 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
it sounds like you have an HEI dist
on the side where the wires plug into it there should be a spot marked tach
(I think)
Old 05-03-2011, 11:10 AM
ones marked batt. and the other says nothing but there are 2 holes on the bottom of the box where the bat. bats. hooked to one hole which is the fat red wire. and the other MUST be tach?
how do i hook my wire into this hole?
Old 05-03-2011, 11:13 AM
SSedan64's Avatar
Should be an empty Spade terminal beside that +Red/Batt wire.
Example>> http://www.msdignition.com/assets/0/...dd418971fe.JPG
http://rmcavoy.freeshell.org/diagrams/HEI_wire.gif
Old 05-03-2011, 11:18 AM
& matts38chev
inside the cap should be a male spade
like in this pic i googled , your tach wire will need a female end to go onto it.
but i dont know wich one it goes on, without seeing it
Old 05-03-2011, 11:58 AM
great success! i was being dumb (there was a side labeled tach ) and i hook it all up. had some trouble figureing out where to hook the light(white) and red(for what ever but needs to be hooked to an accessory) wires but i ended up spliceing them bolth onto my raido wire that runs to my fuse box. was the easiest to access and right out in the open. WORKS GREAT! thanks guys for all the help cant wait to drive to work. but im not sure if its accurate? it says im shifting into second (auto tranny) at 1500 rmps? maby its because i was driving very very slowly. but it read perfect at idle. so ill cobb on it alittle and see where its shiftin then. againe thanks for all the help. i know why i joined this forum. VERY quick responses and very accurate.
Old 05-03-2011, 11:59 AM
another thing. i was reading up on hei dis. and it says that my timing is electronical controled (thats what hei's do) is this right?
Old 05-04-2011, 06:43 PM
SSedan64's Avatar
The older HEI's use Mechanical & Vacuum timing advance & have 1-wire hookup.
The newer HEI's timing advance is controlled by the ECM or Computer with multi wire connector/hookup.
HEI=HighEnergyIngnition, uses an Electronic Module inplace of the old Breaker Points.
Tachometer diamond mike Engine 0 09-27-2009 08:30 PM
Sunpro tachometer, hook up questions eric32 Electrical 5 03-03-2009 08:03 PM
Tachometer viking Electrical 4 09-11-2007 09:10 PM
tachometer ccw9 Introduce Yourself 2 05-02-2007 11:05 AM
tachometer douhavit Electrical 3 06-09-2004 09:08 PM
