How to hook up original 1950 Chevy fleetline speedometer to T-350 tranny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2013, 02:57 PM
HeavyChevyDeluxe's Avatar
Title says it all. I havent really dug into it yet, just did some researching across other forums to see if it will work, but i couldn't find anything too in depth on the subject.
First off, I have the orginal speedometer and speedometer cable in the car (attached to the speedo not the tranny). My question is, will this cable mate to the th350 tranny? If not, will a th350 speedo cable mate to the original 1950 speedo? If neither of those work, do they make any sort of adapter fittings (either for the tranny side or speedo side) of the cable so the two will mate?
Old 12-17-2013, 03:33 PM
poncho62's Avatar
Wiki Edits: 5
Not sure if yours will fit, but my 51 Ford F1 speedo cable mated up to a T350 Chevy trans.
Old 12-17-2013, 03:45 PM
Cool, that's what I'm hoping is the deal here with mine. I haven't had a chance to screw with it lately, but I'm definitely going to this weekend. I don't see why there would be much of a difference between an early 50's chevy and a 50's ford speedo cable.
Old 12-17-2013, 08:05 PM
It will probably will work just fine. If not go to a speedometer shop and they can make you a cable and housing with whichever ends you might. need. When it comes time to calibrate your speedo the driven gear in the trans changes about 3miles/tooth.
BB
Old 12-17-2013, 08:09 PM
Awesome! Thanks booth. Im sure once i get it hooked up it'll be off considering i have 373 geats.
Old 12-18-2013, 03:39 AM
junior stocker's Avatar
Worked fine on a 350/Powerglide (aluminum) into a 51 Chevrolet Bus Coupe; just had to give it a little tug to reach is all. Butch/junior stocker.
cable, chevy, speedometer, th350
power steering on an original 1950 ford dinkus Suspension - Brakes - Steering 5 12-10-2012 08:58 AM
1950 Fleetline elec componet scoulter1 Engine 2 08-07-2012 01:36 PM
Speedometer cable hook-up latebloomer Transmission - Rearend 2 06-02-2010 09:29 AM
Speedometer Hook Up Ron Fowler Transmission - Rearend 3 07-19-2003 02:56 PM
need to know if a 350 will hook up in a 2001 chevy with a v6 5speed trans fred taylor Transmission - Rearend 2 01-08-2003 03:56 PM
