How hot do the A.I.R. tubes get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2007, 09:55 AM
Ozz1967's Avatar
Air Force Guy
I recently put in a new set of plug wires but no matter how I route them they end up resting on the A.I.R. tubes coming from my headers. Does anyone know if they get hot enough to melt the plug wires?
Old 01-22-2007, 12:59 PM
327NUT's Avatar
They should'nt get that hot but I still would'nt let them touch the tubes. Can't you use some wire loom holders/seperators to reroute them?
Old 01-22-2007, 01:57 PM
Ozz1967's Avatar
Air Force Guy
I bought two separate wire looms, but because of the A.I.R. tubes, they don't fit. There is loom from Summit that I'm looking at, but it's yet another $40.00 with shipping to get them. I was just hoping I could leave the plug wires where they are without hurting anything.
Old 01-22-2007, 03:23 PM
327NUT's Avatar
Without seeing it then its hard to make suggestions, and if you don't want to spend anymore money on it then I would just wrap some thermal insulation, like header wrap around the tubes in the proper location and wire tie the plug wires to the insulation. I know that sounds kinda hank but sometimes you just gotta do.....and I'm assuming its not a show car.....
Old 01-22-2007, 03:54 PM
Ozz1967's Avatar
Air Force Guy
It's for my 1984 Trans Am. I put headers on it and then arced one of my plug wires to the headers. So I bought a new rotor, cap and plug wires along with this sweet wire loom from Summit...only because my Headers are emission legal, and have the A.I.R. tubes, it don't fit. I routed the wires and no matter how I route them, there is some point where they are touching the tubes. This is especially prevelant on the drivers side, numbers 1 and 3 cylinders. It's not a show car by any means, I just want it to work right and not arc another plug wire two months down the road from insulation breakdown.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Hot rod builders wanted- Western N.C. WoodsEdge Hotrodders' Lounge 16 11-13-2013 01:47 PM
Rebuilt SB running HOT mouseman Engine 12 07-10-2006 10:51 AM
Hot wire and fuse on aux. fan switch rapsag Electrical 13 06-23-2006 08:36 AM
How hot is too hot? henkelphoto Engine 9 06-05-2006 05:04 PM
