How to ID master cyl disc frt/drum rear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2010, 12:35 PM
cyclopsblown34's Avatar
Colorsanding painter
I'm working on a 46 International with a grab bag of parts for a disc front, drum rear conversion. I managed to fit the rotors, calipers and brackets with no problems on front, the rear is a 9" with drum brakes that were rebuilt by the previous owner. The problem is, the current owner bought a booster and master cylinder from other sources. The master cylinder has a small reservoir in front(if I remember right) and the ports are different sizes. The owner says it is a disc/drum MC. If so, should it more than likely have a 10psi holdback valve or whatever it's proper name is integral? How do I check it? Just a pressure gauge on the line?
Thanks,
Chip.
Old 09-18-2010, 02:30 AM
SSedan64's Avatar
Residual pressure valve:
Small reservoir is for rear Drums, M/C should have Residual valve built in for the Drum portion. I'm not sure how many lbs. they are tho'. You could rig up a line & gauge to check.
Is the M/C going on the firewall or under floor?
Res. valves >> http://www.hotrodheaven.com/tech/brakes/#residual
Master Cyl. >> http://www.hotrodheaven.com/tech/brakes/#mc
Brake Tech >> http://www.hotrodheaven.com/tech/brakes/
Old 09-18-2010, 07:05 PM
It's going on the firewall. I rigged up a gauge and figured out it does have the valve integral. Thanks for the reply, suggestion and links.
Lincoln Versailles rear disc brakes doc bob Suspension - Brakes - Steering 4 10-22-2007 12:53 PM
Rear Disc Swap DJRanger Suspension - Brakes - Steering 1 07-20-2007 07:15 AM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Explorer Disc Bbrakes on a 9" Ford Rear End Mustangsaly Suspension - Brakes - Steering 2 10-31-2005 04:18 PM
