How to ID rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 01:01 PM
How to ID rear end
I was told by the guy I bought my coupe from that he was pretty sure the rear end was out of a '57 chevy. How can I know for sure and how to determine the gear ratio? Supposedly it is 3:08 or close to it.
Thanks
Old 02-23-2012, 01:23 PM
RWENUTS's Avatar
If it has a drop out centre section like a ford 9" has then it probably is from a 57. To figure the ratio put a mark on your tire, rotate it one time and count the number of times the input yoke turns. That'll get you close.
Old 02-23-2012, 01:27 PM
327NUT's Avatar
You'll probably have to google a pic of the '57 rear but as far as the ratio you can turn the pinion yoke or driveshaft and count how many turns it takes to 1 turn of the tire. If you mark them with tape or something like that it makes it a lot easier to see. ..3 turns to 1 = close to a 3:00 to 1, 3 1/2 turns = 3:50 to 1 ....etc,
Old 02-23-2012, 01:54 PM
WDCreech's Avatar
Grumpy Old Goat Herder
If it's a posi, nu8mber of driveshaft turns to one turn of the tire. If its an open differential, leave one tire on the ground and spin the free tire two turns. The spider gears have a 2 to 1 ratio.
Old 02-23-2012, 11:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Couple links for ya':
How to check your gear ratio is HERE.
Crankshaft Coalition Wiki article on Chevy rear ends is HERE.
Good luck.
Old 02-24-2012, 12:39 PM
ID the rear end
On the open positraction rear end does it matter which tire is on the ground when you spin the tire to get the ratio?
Old 02-24-2012, 01:50 PM
WDCreech's Avatar
No! I generally leave the passengers side down, but it doesn't matter.
Old 02-24-2012, 11:21 PM
I.D rear end
Thanks for the information.
rear brake lines wheels to rear end center Studedean Suspension - Brakes - Steering 4 12-23-2011 05:38 PM
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 10:19 AM
1/2 tonn burb rear and 1/2 tonna blazer rear.. u joint? boneyard Buick Transmission - Rearend 1 10-08-2006 11:46 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
67ssdiagram showing how the rear sway bar and control arms connect to frame and rear DeathByGreaser Transmission - Rearend 0 02-08-2003 08:10 PM
