How to ID stock Ford 5.0 HO cams??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2004, 09:18 PM
I bought a new cam supposedly from a 5.0 HO crate motor to put in my engine.
It fit in, but turned out to be the old
289/302 firing order (found out when
I was setting the valves and when on #1 TDC am supposed to be able to set #4E
but the valve was part way open!)
Not much for numbers on the cam - on
the back end was "123" and "70-60" or "10-60", and had a yellow stripe around it by the gear (like the yellow stripe
on the Ford roller cam dist gear I guess).
How does one identify a stock 5.0 HO cam !?
Thanks much!
