Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to ID what year a 700R4 transmission is?
Old 01-25-2013, 12:25 AM
mmerlinn mmerlinn is offline
Wiki Edits: 85
Originally Posted by Bobkat View Post
being that I am a novice at automatics I counted the splines on the output shaft. The longer of the two shafts on the front. 30 splines on the long shaft. The shorter shaft has 27 splines. The longer shaft must be the output shaft.
The output shaft is at the opposite end of the transmission from the input shaft. All 700s have output shaft with 27 splines, same as 350s, 4L60s, some 400s, and a few other automatics.
Input shaft counts are all over the board with 700s having either 27 or 30 splines. Just counting the input splines is not enough as some 700s had 27 splines from beginning to end of production. The only 700s that did not have 27 splines were the V8s (and the 6 cylinders using a V8 case) from mid-84 to end of production. All others always had 27 splines.
