How to identify 9" - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2006, 08:52 PM
flaming79's Avatar
Run it if you build it !!
Last journal entry: Almost ready to go cruzn
How to identify 9"
OK, I got a buddy That has a rear end out of a 1964 ford fairlane. He says he thinks its a 9' ford. As far as the measurments he gave me With a little finess I plan on putting it in my 79 camaro and mini tubing it. Is there anyone that knows if this was a option in 64 on the V8 fairlanes and if so how can you tell?
THanks for any help
flaming79
Old 09-04-2006, 09:04 PM
Wiki Edits: 31
if it is a 9" the Id tag should tell. there is 1 of the bottom bolts that on an 8" you can use a socket but on a 9" you can use only a wrench, but I can't remember what bolt it is. '64 was offered with a 9", tho rare. 8" was standard with V8's
Old 09-04-2006, 09:39 PM
flaming79's Avatar
Im not sure on any of this stuff but maybe you can school me. is the 9" mean the ring gear size, what is the diff between the 8" and 9"., Are the housings the same? And do you have any idea what rear end would be in the 6 cylinder 3 speed 64 fairlanes.
thanks
flaming79
Old 09-04-2006, 11:20 PM
redlightning's Avatar
http://www.kevinstang.com/Ninecase.htm
Here is a link,your buddy probably has an eight.
Old 09-05-2006, 02:08 AM
Another side-by-side pic:
http://www.ridgenet.net/~biesiade/Fordrears.html
Old 09-05-2006, 01:19 PM
flaming79's Avatar
Thanks for the info.
That helps alot
flaming79
Old 09-08-2006, 02:24 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Here's the easiest way, it even works for a blind person.
If you can get a socket/ratchet on the lower two bottom housing bolts below the driveshaft/differential pinion then it is an EIGHT.
A NINE requires an end wrench only since a socket will not fit.
For Ford posi identification when you have the chunk out of the housing, look at the ring gear bolts. If the bolts are recessed it is a posi. If the bolts are on a flat surface it is an open.
A simple well kept secret
Oh ya, the light duty nine and the eight both use identical axles and bearings.
In the 70s the axles got slightly fatter but still interchange if the wheel flange to wheel flange distance is the same. Eights were all 57 1/2 inches same as the big Fords 57 >. Even the MII is the same.
I keep hearing rumors that the Maverick was 1 inch narrower but I have never seen one that was.
Old 09-08-2006, 08:09 PM
The Maintenance Geek
The only Fairlane...
coupe that got a 9" rear was the T-Bolt...
the wagons could have had either...
K
Old 09-12-2006, 01:38 PM
xntrik's Avatar
K
The 63-65 Fairlane hipo cars had 9 inch rears with tapered axle housings (2 1/2 inches diameter)
Never saw a wagon with a factory 9 inch.
can anyone identify this braking system? pcoghlan Suspension - Brakes - Steering 6 05-25-2006 02:27 AM
Can you help me identify these 32 Ford spindles? LittleTruck Suspension - Brakes - Steering 4 01-11-2006 10:21 AM
trying to identify a chevy fender i found recently fast68 Body - Exterior 2 11-26-2005 03:53 PM
Can you identify these? Brazz_04 Hotrodders' Lounge 10 09-20-2005 12:58 PM
Can anyone identify this master cylinder? chris57 Suspension - Brakes - Steering 7 09-19-2003 05:59 AM
