how to identify a stoker crank vs stock - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2011, 05:25 PM
is threr a quick way to mesure a crank to make sure u are gitting what the seller is advertising
Old 03-02-2011, 03:30 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Set it on "v" blocks and measure it !
Old 03-02-2011, 04:37 PM
DoubleVision's Avatar
I don`t know of any "Stoker" Cranks, But I have heard of stoking the fire on a steam locomotive. If it`s a aftermarket crank, get the numbers off them and do a search. If it`s a factory crank just look up the casting numbers.
Old 03-02-2011, 05:14 PM
The measure is from the main journal to the rod journal, this distance will be 1/2 the stroke.
Unless you can set this up in some Vee Blocks, it takes a good eye, typically the measure would be the distance from the middle line of the crank running through the main journals to a middle line running through the crank pin to be measured. While a measure can be taken from the top or bottoms of each of the journals to be compared, if the crank has been reground to different sizes on either or both the mains and rods the measurement of the stroke would be slightly inaccurate.
The stroke is the full distance the rod pin travels from its top most position to its bottom most position, this is why the actual distance from main center to rod center will only be 1/2 the total stroke.
Generally the SBC has a noticeable difference in stroke the 283, 302, and 307 having a 3 inch stroke so you're looking for 1.5 inches between journal centers, the 327 having a 3.25 inch stroke which is 1.625 or 1-5/8s inch on center; the 305 and 350 share 3.48 inches half of which is 1.74 or a bit over 1-47/64ths; the 400 is 3.75 which is 1.875 on centers or 1-7/8ths, this is also the popular length for stroker SBCs like the 383. 400 cranks have larger main journals than the 350, however, there are purpose made 383 stroker cranks that come with 350 sized mains.
Bogie
Old 03-02-2011, 05:50 PM
if its reground num. wont work!!
Looking to identify BBC forged crank chomsnik Engine 0 04-20-2010 12:05 AM
Can you identify this hand-crank? tyman00 General Rodding Tech 5 01-14-2006 11:45 PM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 10:54 AM
stock 400 crank 6speedwagon Engine 4 10-22-2003 05:39 PM
4ma crank vs stock clevo crank carnell Engine 1 08-17-2003 05:56 AM
