How important??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2006, 01:59 PM
How important???
How imoportant is it to degree in a cam. On a stock type sbc 350 with a mild cam, how important is this procedure?
Old 01-12-2006, 02:03 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I believe that it is very important, plus its a good practice to get into. I got burnt by not doing it. Just fallow the directions in the kit. I used the kit from Comp Cams.
Steve
Old 01-12-2006, 02:26 PM
It's always nice to know that the cam is ground correctly and to verify the cam is installed exactly like the cam card specs. Since most all our cams are custom ground we degree in each one. With a stock type application lining up the dots will be more than adequate 99.99%. As it sounds like Savman must have found out there is that chance a cam is ground incorrectly.
Old 01-12-2006, 02:39 PM
Aside from the cam being wrong, there is a "tolerance stack up" that should be considered. Quality Control has specs it lives within or, plus or minus so much. Your crank snout keyway is plus or minus, your lower sprocket key way is plus or minus, the sprockets themselves are plus or minus and the cam is plus or minus.
It doesnt take long to see that you'd have to be one lucky S.O.B. to have the cam timing come out perfect without checking and adjusting.
mig welder - ist the current important? tauruz Garage - Tools 13 11-23-2005 07:30 AM
very important oboII question qreturn Electrical 9 12-13-2004 02:31 PM
Read This!!!!! Very Important!!! NAIRB Engine 42 07-18-2004 08:16 PM
how important is measuring.. Zartan Engine 46 01-26-2004 12:40 PM
Important!!!!!!!! fsjimmy Engine 0 12-02-2003 10:37 PM
