how important is position of residual valves?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2014, 07:18 AM
Last journal entry: 41 chevy frame on the move.
I like to know how close do these need to be from master cylinder.
Old 07-21-2014, 07:37 AM
RWENUTS's Avatar
As close as possible.
Older masters had them right in the outlet.
Old 07-21-2014, 10:33 AM
Thanxs.I appreciate your time.
Old 08-02-2014, 05:51 PM
here are where I installed them.Thanxs for the advise
Name:	prohillclimb 41 chevy brakes 114.JPG
Old 08-03-2014, 07:19 AM
RWENUTS's Avatar
Looks nice, but one problem.
You need to put a couple loops in the lines coming out of the master. They way you have it the lines will crack at the flares due to vibration.
Old 08-03-2014, 05:26 PM
Thanxs,I'll correct thee problem this week.
stefanP
Old 08-07-2014, 01:39 AM
Cars, Trucks, Boats
. You don't need the residual valves for disc brakes... for drum brakes, can be anywhere along the line...
The Following User Says Thank You to BuzzLOL For This Useful Post:
PapaG (08-09-2014)
Old 08-11-2014, 03:09 PM
Thank you BUZZ.
Old 08-11-2014, 04:22 PM
RWENUTS's Avatar
Contrary to popular beleife you need a 2# valve for discs if the master is below the calipers like on your frame
StefanP.
Old 08-11-2014, 06:20 PM
I have read that.This is why I have one for the front and one for the rear.I haven't updated anything because I have been busy with the mock up of the body back on the frame with engine and trans in place.Lots of work for one guy.
residual valves slick fil Suspension - Brakes - Steering 0 06-25-2013 11:29 AM
position of residual valve? T Evans Suspension - Brakes - Steering 2 12-13-2012 03:35 PM
Residual check valves Migman Suspension - Brakes - Steering 20 03-09-2010 10:27 PM
RESIDUAL VALVES, for MC below WC. hotrod389 Suspension - Brakes - Steering 8 08-19-2006 05:14 AM
Help installing residual valves upthcreek Suspension - Brakes - Steering 4 02-01-2006 04:03 PM
