Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How important is the primer I use?
Old 09-28-2012, 06:46 PM
novafreek6872's Avatar
novafreek6872 novafreek6872 is offline
Nova Guru
I say chemical strip and get the stubborn spots with a 4 1/2 grinder and a paint stripping disc. Then go over everything with 80 on a DA. Fix your dents at this point (filler),then Epoxy primer (2-3 coats and guide coat n block w/ 180 touch up any spots with metal showing) followed by 2k High build (2-3 coats guide coat n and block 320 dry then 500 wet) followed by paint.
If you decide to strip with 40 grit be extra careful of heat buildup especially on top surfaces, you can warp them.
Please correct me if anything I said is way out in left field, trying to learn also.
Andy
The Following User Says Thank You to novafreek6872 For This Useful Post:
55's 65 (09-28-2012)
