Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How important is the primer I use?
Old 09-29-2012, 11:21 AM
tech69 tech69 is offline
put up or shut up
that's true, but you don't go stripping hoods or decks with them smack dab in the middle of the panel.
I like the rice patties cause they take paint off fast and leave the metal, which make them perfect and the I-Car recommended way to strip for welding at least. I can't argue with what he's doing cause if he's getting areas that don't strip by conventional means, he's saying that it's most likely in corners or odd shape areas which would most likely be stout enough to take that heat without distortion.
