how to install 700r4 in chevy
I have a 66 Nova with a 283 and a Pwr gluide. So, should I get a th350 or a 700r4? I know how to install a th350 but not a 700r4. Is there any secrets. The cost is probably about double for the 700r4....is it worth it?
Not enough background... Justification depends on your use of the car. I it a Racer? Cruiser? Daily driver? Is milage a concern? If it's not a daily driver and just a weekend cruiser figure the added cost for the O.D. and work that back into gas money... Is it worth it? Does the PG work fine? Does it NEED to be fixed if it's not "broken"?
The O.D. trans will cost more up front then a 350TH but is the cost justifiable in your eyes? The swap won't be much different then the 350TH as far as parts goes other then a new wiring harness for the O.D. Just asking... Mark |
Sorry, this is a daily driver. The power glide is just fine. 65/70 mph is 2800 to 3200 rpm a little to high for long trips. Not to mention $3.25 per gallon of regular gas!
I would suggest the th350, just cause they're
everywhere and its almost a bolt on, the cases are about the same size as the powerglide. According to a book i have here are some measurements of the trannys so you can compare and even measure some so you know about how much you would need to fabricate to make fit.. Also if you do quite of bit of traveling i think the overdrive would be great to have.. hope the table below helps on your decision. .........................Case length........Overall Lenght........To trans mount Powerglide Long.....15 1/4"...............27 1/2"...................20 1/2" Powerglide Short....15 1/4"...............27 1/4"...................19 1/2" 350 Short.............21 5/8"...............27 5/8"...................20 3/8" 700R4..................23 3/8"...............30 3/4"...................22 3/8" Last edited by aztek_warrior; 05-21-2006 at 05:29 PM. |
OK I'm going with the 700r4......now anything good and or bad about bowtie overdrives transmissions? This is where I think I might buy.
the TV cable adjustment on the 700 is IMO the #1 cause of trans failure by people installing them wrong, this cable has to be installed and adjusted perfectly for proper function,
a 700 is pretty much a 350 with overdrive, Brendan |
| fitting a blower to 359 chevy with 700r4 tranny | 37 chevy | Engine | 6 | 05-25-2006 08:37 AM |
| 700R4 transmission install | Decho | Transmission - Rearend | 3 | 08-13-2004 11:54 AM |
| Chevy vibration dampner install ????? | onebadmerc | Engine | 8 | 07-31-2004 05:20 PM |
| Chevy small block blower install tuning issues. | subman17 | Engine | 2 | 07-24-2004 11:32 AM |
| 700R4 won't hang in overdrive | slingslingbinks | Transmission - Rearend | 8 | 03-29-2004 09:43 PM |
