how do I install ampere meter on a 1951 gmc
Help...Someone please tell me how to connect the ampere meter...
What goes to the + side and what goes to the - side?... Does a wire go from the ignition switch to the ampere meter(where on the ignition switch to where on the ampere meter)? This is a 1951 GMC, coverted to 12volts with an alternator. Last edited by rongivens; 11-06-2008 at 07:13 AM. Reason: bad question |
Once again I´ll post this about amp gauges from MadElectrical a warning.
When GM installed ammeter gauges in the 60's they used this type of gauge (info is from from the Mad electrical site)
"GM vehicles built with the gauge option also had a more modern design of AMP gauge at the dash. The newer AMP gauge was a remote shunt type design–a length of the battery charging wire in the under-hood harness served as the shunt. The dash gauge and related wiring no longer handled heavy current load. " The shunt type of gauge is safer, but accuracy seems to suffer as they get older. It depend on having a constant, predictible resistance in the charging wire that serves as the shunt. My '76 GMC pickup has a shunt design ammeter, and it has not worked in several years. I'm not sure if its the wiring, the gauge, or the junctions. This weekend I found that the charging wire had insulation so brittle that it pulled apart in my hand, but I haven't checked to see if my wire repairs will give me a working gauge. I'd leave the old ammeter in the dash, just for looks, and use a voltmeter for your real working gauge. Bruce |
| 1951 gmc truck | Chad1965 | Introduce Yourself | 8 | 04-16-2009 08:33 PM |
| 1951 Stude pick-up SIDE DOOR WINDOW INSTALL HELP! | 39chevy | Body - Exterior | 2 | 02-27-2008 08:00 AM |
| 1951 Stude pick-up, door window install, HELP! | 39chevy | Body - Exterior | 2 | 02-12-2008 07:14 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| Spindle interchanges | bskaggs | Suspension - Brakes - Steering | 11 | 06-05-2006 01:29 PM |
