How to install gear to gear timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2009, 09:25 PM
I have a dual idler timing gear (gear to gear timing) that I'm not quite sure how to install. I have a 350 sbc. One side of the idler gears has two flat sides. The other side has one flat side and one raised stud. The gear with the stud is slightly larger. When I install it, does the stud end go in toward the block (and which gear goes on what side) or does the stud face out? Also on these 350's, what holds the cam in? I didn't notice anything that keeps the cam from sliding forward.
Old 08-03-2009, 10:05 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Did it come with instructions? If not, what brand is it? You can probably go to the manufacturers web site and download the installation instructions.
Old 08-04-2009, 06:51 AM
It doesn't say. I bought two motors(a 305 and a 350) from a guy but they were in pieces. I'm rebuilding the 350 and I came across the gear to gear timing in my bucket of parts.
Old 08-04-2009, 07:09 AM
SSedan64's Avatar
http://static.summitracing.com/globa.../sum-g6700.pdf
http://static.summitracing.com/globa...bigblockch.pdf
http://static.summitracing.com/globa...s/cca-4100.pdf
Old 08-04-2009, 08:25 AM
The dual idlers should just slide into place, you might need to turn the cam a tiny tiny bit to get it to seat 100%
Old 08-04-2009, 10:45 AM
Thanx for the Summit links, that helped me out. The funny thing is I called the tech support at Summit and asked him and he said the large gear goes on the left which is right but said the tapered stud points to the timing chain cover, which is wrong. It's suppose to go in toward the block but not touch it. LOL and autozone had all the info wrong. Thanx guys
How do I remove the timing chain on a 350? piniongear Engine 9 09-20-2010 09:39 PM
Timing Mark (Gear) orientation dirtinla Engine 9 01-15-2009 03:20 PM
SBC front timing cover install question v8hed Engine 5 07-26-2008 12:04 AM
Timing/carb idle mixture adjustment DENCOUCH Engine 7 07-21-2008 11:50 AM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 10:01 PM
