How to judge engine wear - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2012, 10:25 PM
Last journal entry: Front suspension update
A neighbor of mine has a 350 chev that i'm thinking of buying. But him nor i know how much wear it has. He doesn't know how many miles the wrecked camero he pulled it from had, and he has used it some since. Is there a way to determine wear without major disasembly?
Old 12-03-2012, 11:04 PM
Lift the valve covers and look for sludge. Check out the oil that's in it, if any. Check the condition of the spark plugs. Why not just pull the heads off it and really get a good look?
The Following User Says Thank You to Nuck Chorris For This Useful Post:
azlogger (12-04-2012)
Old 12-03-2012, 11:15 PM
vinniekq2's Avatar
cylinder leak down tester,compression guage,micrometre,
Old 12-04-2012, 06:13 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Vacuum gauge, reading manifold vacuum at idle says a lot about condition of valves, rings, ignition.
The Following User Says Thank You to cucumber1949 For This Useful Post:
Old 12-04-2012, 10:31 AM
Thanks all. idk why i didn't of checking compression...
You be the judge. DoubleVision Hotrodders' Lounge 2 12-21-2009 09:24 AM
crank journal wear specs on 305 engine fast68 Engine 4 02-25-2007 08:34 PM
69' Gto Judge james MCclure Engine 3 06-17-2004 04:10 AM
Is priming the engine suppose to wear my drill out? sizemoremk Engine 16 08-19-2003 02:52 AM
What's A Car Judge To Do Benji Hotrodders' Lounge 6 06-02-2003 12:34 PM
