How to keep chevy truck bed sides straigt - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-30-2012, 11:50 AM
chevyhotrod's Avatar
I used 16 gauge steel. maybe it would have been better if i had used 14 gauge.
I looked at aftermarket ones and they are also 16 gauge.
I did not want to make the truck to heavy.
  #17 (permalink)
Old 01-30-2012, 12:32 PM
No 16 gauge is plenty anything less and you really would have had problems. With the way you have created weld nuts on the inside of the fender I would think that torqing them down in a certain sequence could affect how the bedside stays flat. Try different sized shims between fender and bedside. At each bolt. Other than that I think you will just have to keep messing with it until your satisfied. Good luck to you. Beautiful truck
50 ford reversing spindels on opposit sides ? 39 pu guy Suspension - Brakes - Steering 1 11-02-2010 09:06 AM
Blew fuses on both sides of relay. Any ideas? cboy Electrical 8 09-10-2010 10:36 AM
32 Ford Hood Sides Glenn Ellstrom Body - Exterior 1 08-27-2007 01:29 PM
Do you need to bleed both sides of a 4 port master cylinder brian400ex Suspension - Brakes - Steering 2 03-23-2003 10:30 PM
Has anyone ever siliconed an intake on all four sides? CrazyT Engine 3 03-16-2003 06:32 AM
