How to keep thread from unwinding off spool? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2012, 04:06 PM
I've got a couple of spools of thread now, and they seem to like to uncoil down around the base when not in use.
Any hints on storing spools properly?
Old 02-06-2012, 06:34 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
The spools I have have a small notch to catch the free end of the thread when not in use...
Sam
Old 02-07-2012, 04:33 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I don't know what size spools you have, but larger spools have a plastic insert in the top center of the cone. I pull out the insert and catch the end of the thread between the insert and the cone. You could also use a wide rubber band.
New spool - Need help S10 Racer Transmission - Rearend 2 04-25-2010 08:25 PM
spool vs. mini spool 72fordlb Transmission - Rearend 7 11-14-2009 02:44 PM
Full Spool or Mini Spool??? S10 Racer Transmission - Rearend 1 04-02-2008 06:50 AM
difference/pros/cons of spool and mini spool? "70" Cougar Transmission - Rearend 20 03-03-2006 10:42 AM
What's a spool and mini spool? 84Z Transmission - Rearend 2 01-31-2005 07:33 PM
