Well a new project has swooped in for this christmas break, instead of starting the rebuilding process of my 400 small block, I will now be replacing my rearend in my 1991 silverado. I was wondering what information you all had on the ratio it may have. Another thing I was wondering was has any one put a limited slip (posi Track) in there truck? If so I was wondering what is a good kind to go with. I was also wondering if anyone had any advice on how to calculate the ratio so if I end up going to a junk yard I would like to be able to calculate what ratio in it and be able to know if it has a positrack in it or not? Thank you in advanced to all the much needed advice that you all have and may everyone have a Merry Christmas!!
Is it a ten bolt cover or a 14 bolt cover..that makes a bit of difference..Could be a 3.08 a 3.42 or a 3.73.. some of those were 4.10 ratio.. Posi or a locker would be a good investment on one of those trucks if you do not already have one..
You have the 8.5 10 bolt with 30 spline axles. There is a white sticker in the glove box with a bunch of codes on it. The codes that start with a G are the rear end codes. The gear ratios go like this, GT4=3.73, GU6=3.42, GU5=3.23, GU4=3.08, GU3=2.73. The Eaton Governor Lock was the only limited slip differential offered in these trucks. The code for this is G80.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
