How to know what kind of rearend I will need for my 1991 chevy silverado - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2013, 07:56 PM
SilveradoRunner1991's Avatar
Well a new project has swooped in for this christmas break, instead of starting the rebuilding process of my 400 small block, I will now be replacing my rearend in my 1991 silverado. I was wondering what information you all had on the ratio it may have. Another thing I was wondering was has any one put a limited slip (posi Track) in there truck? If so I was wondering what is a good kind to go with. I was also wondering if anyone had any advice on how to calculate the ratio so if I end up going to a junk yard I would like to be able to calculate what ratio in it and be able to know if it has a positrack in it or not? Thank you in advanced to all the much needed advice that you all have and may everyone have a Merry Christmas!!
Old 12-15-2013, 08:01 PM
Also, my truck is a 1/2 two wheel drive with a stock 350 V8 if that changes the type of rearend it would possibly have
Old 12-15-2013, 08:54 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Is it a ten bolt cover or a 14 bolt cover..that makes a bit of difference..Could be a 3.08 a 3.42 or a 3.73.. some of those were 4.10 ratio.. Posi or a locker would be a good investment on one of those trucks if you do not already have one..
Sam
Old 12-15-2013, 08:56 PM
techinspector1's Avatar
Wiki Edits: 326
Buy yourself a FACTORY SERVICE MANUAL, then you will know absolutely everything there is to know about your truck.....
Faxon | Shop Manuals for Car & Truck Owners | DIY Service, Repair or Maintenance
Old 12-15-2013, 09:24 PM
Sam
It's a 10 bolt rear end, and is a locking differential easy to install?
Old 12-15-2013, 09:52 PM
big gear head's Avatar
High Performance Rear Ends
You have the 8.5 10 bolt with 30 spline axles. There is a white sticker in the glove box with a bunch of codes on it. The codes that start with a G are the rear end codes. The gear ratios go like this, GT4=3.73, GU6=3.42, GU5=3.23, GU4=3.08, GU3=2.73. The Eaton Governor Lock was the only limited slip differential offered in these trucks. The code for this is G80.
The Gov Lock isn't a very good differential. I recommend the Eaton Posi or Yukon Dura Grip for a replacement. Here is how you install it. http://www.nastyz28.com/forum/showthread.php?t=19773
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (12-15-2013)
Lowering of my 1991 Chevy silverado ext. Cab SilveradoRunner1991 Suspension - Brakes - Steering 12 12-07-2013 08:31 AM
1991 chevy silverado question eandabailey Hotrodding Basics 4 02-08-2012 09:39 AM
1991 chevy rearend? 1991 chevy Transmission - Rearend 3 01-27-2011 10:15 PM
1976 chevy C10 where to buy a rearend or what kind? Cbratcher16 Transmission - Rearend 10 10-07-2008 02:45 AM
What kind of rearend is in a 2001 Silverado? Dubz Transmission - Rearend 4 12-28-2003 05:24 PM
