Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to lift the rear on a 1971 camaro?
  #16 (permalink)
Old 05-15-2011, 05:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 1badLemans
Bye the way, Cobalt please explain why shackles would be ideal??? And no, tires or wheels don't stick out at all. The guy just wanted as much tire contact as he could being that this car was going to be built as a street/strip car.
I said they would NOT be ideal, and the reason is because jacking the a-- end up in the air changes the camber of the front end along w/doing nothing good for traction, handling or even braking/safety.
But if you've taken this and the other downsides into consideration and you still want to use them- go for it. Just don't make it sound like it's the correct way to set up a rear suspension for best all around traction and handling. The ONLY thing long shackles on an otherwise stock vehicle has going for them is they are cheap and any hack can usually install them, if they can borrow a big enough piece of pipe to put over the end of their crescent wrench to break the nuts loose.
