How to lift the rear on a 1971 camaro? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 06:45 PM
1badLemans's Avatar
Hey guys, I just bought a 71' camaro that the previous owner put huge tires and exhaust exiting in front of the rear tires. I have a steep driveway and the pipes scrape when driving into my garage which is annoying as well as scraping over speed bumps. I haven't had anyone in the back seat yet but previous owner says tires will rub if adults are in the back. He did install air shocks with electric compressor and switch to activate but I see no lift just stiffer suspension. Ok, what would be the best way to raise the back about 2 or 3 inches? I would like to acomplish this not only for clearance, but I love the raked look of a muscle car. I've heard that air shocks are crap and to just toss them but in favor of what? I've done some research and think extended shackles woud be the cheapest and easiest way to do this. I know handling would suffer but this is a weekend car and I don't like driving fast around corners, that's how you loose control. Drag racing in a straight line is my taste of racing. What would you suggest?, thanks.
Old 05-14-2011, 07:26 PM
Altec's Avatar
Bottle Of Whiskey
Longer shackles, and correcting shims for the pinion angle?
Another possible option is some sheet metal work. This is what we (My Father, and myself) did to tuck up the exhaust up on his '69 Camaro.
http://i13.photobucket.com/albums/a2...o/100_5022.jpg
Old 05-14-2011, 08:16 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
i'm thinking smaller tires and different exhaust would be better
and then to get the "raked looked of a muscle car" lower the front a little
Old 05-14-2011, 08:54 PM
1badLemans's Avatar
Any idea on how much I can lift before it drastically affects pinion angle?
Old 05-14-2011, 09:12 PM
Longer shackles and shock extenders.
Old 05-14-2011, 09:20 PM
Altec's Avatar
Bottle Of Whiskey
Best thing you can do is lift the back of the car up with a floor jack (Not from the axle...) enough to get the weight off and unbolt the shackles. Then jack the car up to the desired height. Slide jack stands under the car, and crawl under and measure the pinion angle, and measure the transmission while you are at it. You can figure out if you are within spec from there. If not, shims will do for your purposes.
Next I would pick up some flat bar stock and cut it into 4 equal length pieces, and drill a bunch of holes every 1", or so. These will act as test shackles so you can figure out how long of a shackles you need for the desired height. From there you can either buy, or make a set for the desired length/hole spacing.
Old 05-14-2011, 09:39 PM
Pantaz's Avatar
If you want to keep the existing ride height, you can install air-bag "load helpers" with on-board compressor (the compressor is really small). Just pump the suspension up temporarily to get in your driveway, or over speed bumps.
Old 05-14-2011, 11:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
For the scraping exhaust, reroute it and tuck it up under the car properly. Nothing looks cheesier than the exhaust/mufflers hanging below the car- well, except air bags that jack the tail end up to clear too wide/wrong offset and/or backspaced wheels that extend out past the rear quarters. If the wheels don't hang out, a slightly longer shackle can give you some clearance, but isn't the ideal solution.
If the tires are scraping on the inner fender lip. the lip can be rolled back to give some extra clearance. If the scraping is on the inner side of the wheel, scraping can be reduced using thin spacers- but they have to be thin, as in 3/8". If this isn't enough, the wheels should be swapped for the correct size.
Old 05-15-2011, 06:12 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 you need the correct fitting parts if you want it to ever sit right JMO
Post a pic of what you have going on now with it would be nice.
Cole
Old 05-15-2011, 06:40 AM
poncho62's Avatar
Wiki Edits: 5
New springs.................
Old 05-15-2011, 08:21 AM
eloc431962's Avatar
Wiki Edits: 37
Yep that too......
Cole
Old 05-15-2011, 02:51 PM
1badLemans's Avatar
Car kinda looks like a challenger T/A exhaust which I personally don't find cheesy at all Cobalt. Tires are fine and don't rub at all like I said until I maybe have people in the back seat. I will try to post pics as soon as I can, but shackles and shock extenders seem like a good route.
Old 05-15-2011, 03:14 PM
1badLemans's Avatar
Bye the way, Cobalt please explain why shackles would be ideal??? And no, tires or wheels don't stick out at all. The guy just wanted as much tire contact as he could being that this car was going to be built as a street/strip car.
Old 05-15-2011, 04:41 PM
Altec's Avatar
Bottle Of Whiskey
For your use, the shackles are fine.
I can't find a lift spring for a 1971 Camaro... So you would either have to have yours re arched which give you a crappy shackle angle, and will ride like a dump truck. Or you can get a custom set made, and deal with the sore rear end when they bend you over, and still have ride that isn't ideal...
Old 05-15-2011, 05:12 PM
poncho62's Avatar
Wiki Edits: 5
Chances are the leaf springs are old and sagging....New springs will bring it back to proper height.....If not, add one leaf.....That's not expensive....and its not rocket science.....
1971 SS 396 Camaro scottyo Engine 5 03-16-2010 11:45 AM
first gen. camaro rear spoiler on a 1971 chevy nova chevymastermind Body - Exterior 0 07-08-2007 07:21 PM
How To lift The Rear Of A 69 Camaro JimKramer Suspension - Brakes - Steering 4 09-16-2005 04:14 PM
posi unit for 1971 Camaro todel1223 Transmission - Rearend 2 09-12-2005 11:22 AM
Independant rear for 1971 Nova KING_NOVA Transmission - Rearend 1 10-24-2002 05:32 PM
