How To lift The Rear Of A 69 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2005, 03:45 PM
Hey guys,
I have a restored 69 Camaro and I want to lift the rear end up just a little (about 1") I don't want to use air shock for such a short lift and I don't want to extend the shackles. I think that looks tacky. Does anyone have any suggestions on what I can do? Do they make a coilover shocks for the rear if that would even work. Any suggestions would be appreciated. Thanks
Jim
Old 09-16-2005, 04:15 PM
sicksixseven's Avatar
Ground Clearance Is Over-Rated
Im not farmiliar with the camaro rear end, does it run leafs or coils?
Old 09-16-2005, 04:21 PM
rrmccabe's Avatar
GM Muscle
You can have the springs re-arched. I think coilovers are just about as bad as air shocks. I agree about the shackles and can remember my Superior 500s on my first car (67 Camaro). Hung way down from under the car.
Can you extend the shackles to get your inch without having them fall below the rear valence?
Personally, I think replacing the springs or arching them is the best fix.
Rich
Old 09-16-2005, 05:07 PM
You could do one of two things for a very cheap amount of money. Either go down to autozone and order a set of 1 lift/lower blocks or get and add a leaf kit. Either one will give you one inch of lift.
Old 09-16-2005, 05:14 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
lift the rear
if you dont want to buy shackel make them yourself. go to a local steel shop and tell them you want 4 peices of 3/8 steel with 2 9/16 holes punched in each one. you will have to measure your current hole centerline and just add an inch. I got mine for about 20 bucks.
one piece fiberglass front end for 69 camaro??? chevyelc81 Hotrodding Basics 8 05-10-2011 12:39 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
68 Camaro Front / Rear Tire Width / BS - Whos running what? 68CaliCamaro General Rodding Tech 0 12-29-2003 06:51 PM
69 Camaro Air Suspension (bags?) Front G_Ecker Suspension - Brakes - Steering 2 12-24-2003 03:50 PM
Monte Carlo rear into a Camaro rear? redcamaro4spd Transmission - Rearend 2 12-19-2003 02:16 AM
