Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How light can a SBF get? w/iron block.
Old 02-10-2012, 11:10 AM
Canzus's Avatar
Canzus Canzus is offline
a red wool sock on his dinger
I'd say in the neighborhood of 390lbs, using alloy heads, tin valve covers, and carbed,
not injected. The starting point would be a '90ish 5.0, as they're the lightest blocks, if you
can find a 255cid crank, they're lighter than the 5.0L by 8 or so lbs...
