how to lock a toolchest - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2009, 01:30 AM
72 grabber 51F-1 65 chevystang
I am starting diesel mechanics in a few weeks. I am running a little short on money so I am going to take in my box. I will have about $1200 in toos in it and am wondering if anyone knows how to make a locking device for them. It is one of the craftsmen ones.
Old 08-06-2009, 04:51 AM
302 Z28's Avatar
I have seen mechanics who have installed part of a hasp & hinge on their tool boxes. They use just the part that the lock would go though. They use two of them, one on top front and one on bottom front. They they pass a steel bar through both of the hasp's. The steel bar has a hole drilled through each end and they pass a lock through each hole. This blocks all drawers. Hope I explained it well enough.
Vince
Old 08-06-2009, 09:37 AM
life is a temporary assignment
Tie a pit-bull to it !!!! LOL.. Just joking..You don't want to do that.... Vince has a great idea there..
Old 08-07-2009, 02:58 AM
4 Jaw Chuck's Avatar
FYI you can break into any toolbox with an exposed hinge by tapping the hinge wire and then pulling it out with a pair of pliers...so unless your willing to do the front and back with lock hasps...
You get the picture.
My opinion is if they want in they will get in, every shop has a 6 inch angle grinder laying around that can make short work of any lock. I would just use the supplied toolbox lock, its not great but it will prevent the casual light finger perp.
Old 08-07-2009, 01:56 PM
302 Z28's Avatar
I had the same thoughts and almost posted such, but I have seen boxes locked as I described so I posted it. Me personally I think as you....a complete waste of time.
Vince
Old 08-07-2009, 06:56 PM
boatbob2
locking tool box....
Hi,i had a 2 piece craftsman tool box, i had my wife sew up a padded vinyl cover,, (like a big sock)i pulled it down over the whole box,then i took a chain over the top of the box (front and rear,then with the same chain,X ed it side to side,make the chain tight,then get a BIG master lock thru the chains.it would be better,if you had something to chain it to (car bumper works well...good luck.....(((or take it home every nite)Randys blurb about the pit bull,is right on.......
Why only one door lock on a Ford F-100? Z-Money Pit Hotrodding Basics 38 12-30-2011 05:44 PM
700r4 lock up confusion jrs22166 Transmission - Rearend 4 07-28-2009 08:35 AM
700 lock up convertor tinman386 Transmission - Rearend 5 04-25-2009 04:21 PM
Anyone ever had a line lock fail and degrade braking? sizemoremk Suspension - Brakes - Steering 7 09-22-2006 02:13 PM
