How long is cam breakin lube good for? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2007, 06:30 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I'm going to put a motor together this winter that I probably won't fire up until the end of the summer, is that okay? I'm worried about the cam lube coming off the cam, I don't want to wipe it on break-in!
Old 01-27-2007, 06:42 PM
327NUT's Avatar
I think you would be ok...put plenty of lube on the lobes and bottom of lifters when you install cam BUT then dont turn the engine over if at all possible as to not wipe the the goop off the parts. Be sure to use a pint of GM engine oil supplement (EOS) and prelube the engine just before firing. Good luck
Old 01-27-2007, 07:09 PM
Bare Knuckles Champ
Last journal entry: Made a wrench...
Make sure you lube the cam bearings, as well. And a top quality assembly lube, I believe in Redline.
Emphasis on PRE-LUBE before start up!!
Old 02-01-2007, 10:25 PM
Be sure you use a lube that won't run off. Some of the cam makers sell a runny lube that won't last as long as you need it to.
Old 02-01-2007, 10:58 PM
Wiki Edits: 2
What are some good thick lubes? I have a tube of thick dark moly assembly lube, is that stuff any good for the cam?? its called "max tuff" or something like that.
Old 02-02-2007, 12:46 AM
techinspector1's Avatar
Wiki Edits: 326
Clean the oil off the cam and lifters that was put there by the manufacturers with solvent. Then wash both cam and lifter faces with dishwashing detergent and hot water. Then sit down with a can or jar of molybdenum disulphide (that black, thick grease that comes with the cam) and massage it into every part of the cam and lifters that will mate up on assembly with your hands.
Add a bottle of GM EOS to the engine oil like 327NUT said and install some worn-out stock valve springs in the heads. Use them for break-in, then change them out for the springs the manufacturer recommends to run with your cam and lifters after you've run the motor about 50 miles. Use a top quality racing motor oil that has the additives in it that have been taken out of regular oils.
A little caution now will prevent tearing the motor down to clean it out and buying another cam and lifters to do the job again.
Are those mile long sanding blocks a gimmick? MARTINSR Body - Exterior 43 11-06-2006 07:03 AM
What is a good jet boat cam ? Haulin327 Engine 10 04-26-2006 11:39 AM
which cam sounds good not piggish spinn Hotrodding Basics 23 10-25-2004 04:15 PM
Whats a good cam for me RiceMuncherdude Engine 7 03-07-2003 07:41 PM
What's a good cam grind for pulling power? stfinney Engine 5 12-06-2002 03:56 PM
