How long do you think it'll last? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2005, 08:02 AM
Hello all,
I have a 66 Caddy that had a vinyl roof which upon removal had some pretty major rust (surface, pits, holes) on the sail panels. I've cleaned up the majority of the rust with a wire wheel and some naval jelly and have welded the holes. My next step was to apply some tiger hair.
My question is that in some areas there is still some rust that just doesn't seem to want to come out of the pits. I know ideally I should cut it out and fabricate a patch panel, but how long do you guys think it'll last if I went ahead and fiberglassed the whole sail panel?
Thanks in advance for any suggestions.
Old 10-24-2005, 08:42 AM
roger1's Avatar
Keep putting Naval Jelly on the pits and power wire brush them after washing off. After several iterations of the this, you will get all of that black rust out of the pits.
Reverse the direction of wire brush wheel often so the bristles don't bend in one direction. Then check the deep pits with an awl to make sure they haven't turned into small holes. Weld any small holes up with your Mig and weld in patches for any larger holes.
Apply an epoxy primer first, sand it and then use filler. I like to use the Evercoat fiberglass filler instead of the kitty hair.
Hard piping air lines ... help (LONG) candygram Garage - Tools 19 10-18-2005 06:23 PM
detonation resistance, short or long rods? Old School Nut Engine 34 12-31-2004 12:23 AM
How long will lacquer primer last? ChrisMiddleron Body - Exterior 2 06-17-2004 05:35 PM
350 long block worth crshrmn3 Engine 1 10-01-2003 11:54 AM
H-pipe, How long? 85CHEVY Engine 12 09-25-2003 07:11 PM
