How long does epoxy primer take to dry - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2012, 03:33 PM
rusthater89's Avatar
I am using Summit Racing Epoxy.
Today I sprayed the hood on my Firebird. It is warm around 72 Farenheit.
I returned about an hour and 15 minutes after I sprayed. I touched the panel and it felt dry. I lifted the hood and moved it against the wall in my garage. When I looked I had prints from me handling it. (Like the primer was still soft underneath?)
Anyone have an idea when it would be safe to handle.
Bummer too, I used rags to hold the hood so the edges don't cut my hands and now I got rag fibers stuck in the primer.
Old 07-22-2012, 08:15 AM
302 Z28's Avatar
I've never heard of that brand of epoxy but using SPI I can tell you it can take several days to reach it's full cure. You can help the cure by placing the parts in direct sunlight.
Vince
Old 07-22-2012, 08:47 AM
SPI takes 7 days to reach its full cure, but it's 'dry' (as in you can handle or sand it) well before that.
If I spray something with epoxy I give it a good half day at least before I touch it. Most of the time I spray it and just come back the next day to do anything.
Old 07-22-2012, 09:52 AM
Vince
I have noticed that as well. I was just wondering how long it would be before I can handle it.
Old 07-23-2012, 06:21 AM
deadbodyman's Avatar
Wiki Edits: 11
Half a day sounds good to me...for handling..
The Following User Says Thank You to deadbodyman For This Useful Post:
rusthater89 (07-23-2012)
Old 07-23-2012, 06:31 AM
Thanks, I guess next time i'll go shower, eat first, and get chores done before moving it.
Old 07-23-2012, 10:38 AM
67Elcamino's Avatar
Im not that experienced but have shot 3 different epoxy primers in the last year. I would recommend waiting 24hrs especially if you shot more that one coat or a heavy coat.
Also noticed the temperature effects it alot. I think the best bet before risking adhesion issues from your next coat is to contact the company. Ive noticed all of the ones Ive used vary
What is the difference between singe stage epoxy primer and 2 stage epoxy primer rusthater89 Body - Exterior 16 06-01-2012 09:06 PM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
epoxy primer -how long ditonics Body - Exterior 36 01-04-2010 01:42 PM
How long is too long to wait after sanding poly primer before i can spray a 2k? misteryu Body - Exterior 2 03-17-2006 09:49 PM
How long should it dry scheetz93 Body - Exterior 7 10-19-2005 09:32 PM
