If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
if you are only wanting them checked, not machined; a shop can "usually" check them in a couple of days depending on their schedule. if you are in good with the shop, and the have the equipment open they will sometimes do it on the spot.
i guess it depends how good of a customer you are:mwink:
Where are you located? If your near mid Missouri you can get head magnafluxed with same day service due to fact that the plant I worked at has closed. If they're clean and dry I'll magnaflux them while you wait for free.
If it's a set of small block heads: cleaned, magnafluxed, resurfaced: 1-2 hours if the guy is in a hurry. Plus, we'll check the valve for sealing.
tom
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
