Hotrodders Bulletin Board
#1
How long does a wet magnaflux usually take?
Exactly as the title says. I have a crank at the shop that I took in Saturday to get wet-magged as well as balanced (pending that it didn't come back cracked). He said he would look at either Monday/Tuesday and get back with me. He never called. Now, I have no idea how the process goes, but it's now Thursday and he still has yet to come to any final conclusions as to the status of my crank. Now, I can understand that you can get busy, but how long does the actual process take? More than a day?
Thanks. |
#4
Those before me here have it corect. Once the cranks are cleaned and lined up it takes a matter of minutes.
Are you sure this guy actually has a Magnaflux machine? Or, a magnetic particle inspection machine. Ask to see it. If he says he's doing it with spray cans, get your crank and leave. Maybe he sends them out or waits until he has several to do. |
#5
I'm fairly certain he has a Magnaflux. He mentioned that he 'loaded the liquid..' and something else to the affect that it was cost efficient to do it this way, something or rather. I doubt he's doing it by can. Managed to get him on the phone earlier today. Said he did it once, but it wasn't definitive, and that a film of oil/humidity (both present) could cause bad results. he said there was a 'suspicious' spot under the snout and near the middle of the crank. I'm hoping that's the case, but 4, going on 5 days seems a tad much. |
#6
Oil and humidity? Oil means he didn't clean the crank properly. Humidity? The magnaflux solution is water based, looks like milk. The solution could be poured over the crank from a water glass, but has a low volume pump and nozzle to wash the solution over the crank journals. You're getting a run around.
#7
Yea, thought so. He kept saying he'd call me, but never did. I called him today, he said the magnaflux came back OK and the crank wasn't cracked. I don't think he washed it the first time either. This will probably be the last time I use him. He said he's going to have balancing done by Monday. We'll see if he sticks to that..
Thanks for the help. |
#8
Make sure he gives you a certification that the crank was magnafluxed AND found not to be cracked!
I see this a bit here and there. People saying such and such was magnafluxed. Yeah? and what? Was it cracked? Was it magnafluxed and found to be cracked and your selling it because it was cracked? Just saying it was magnafluxed doesn't mean it passed the test. Items that passed magnafluxing should have (at the miminm) a magnaflux brand name sticker saying "passed inspection" on the part as well as written documentation supporting the sticker and referencing the particular part. You should have an identifying number or your initials engraved or stamped on the part. It sure works well that way on aircraft parts. |
Back to top |
Similar Threads for: "How long does a wet magnaflux usually take?"
| Long or short water pump? SBC-Bracket Configuration etc. | Elevinpointsixtoone | Engine | 8 | 12-03-2008 07:01 AM |
| Need advice on short and long term rocker panel repairs | weekender | Body - Exterior | 4 | 04-11-2008 10:36 PM |
| detonation resistance, short or long rods? | Old School Nut | Engine | 34 | 12-31-2004 12:23 AM |
| wet sand signal stage | scheetz93 | Body - Exterior | 4 | 08-21-2004 11:34 PM |
| Sanding, Dry vs Wet, Air vs Elec | Bluepen | Body - Exterior | 3 | 05-12-2003 03:45 PM |
