How long should it dry - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2005, 07:35 PM
scheetz93's Avatar
Hi guys I bought a 2005 mustang. I want to make it look like the prototype roush. On the prototype the lexan was removed from the headlight and the plastic bezel was painted. I was wondering how long should I let the bezels dry before I seal every thing back together. Some one said I should wait 2 weeks to make sure the solvent is all dried up
thanks guys
ID:	7383   Click image for larger version
Old 10-19-2005, 05:11 PM
scheetz93's Avatar
no one can give me any help???
Old 10-19-2005, 05:34 PM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
Are you doing this in an air dry environment?
Old 10-19-2005, 06:06 PM
scheetz93's Avatar
it is in a paint shop, I am not personally painting them I just pulled the headlights off and pulled them apart!
Old 10-19-2005, 08:24 PM
crashtech's Avatar
Technician
Wiki Edits: 17
If they are done in a baking booth then most of the solvents will be gone by the time you get them back. Most headlamps are not totally airtight, they will usually have a small vent somewhere, so I don't think you will have a problem.
Old 10-19-2005, 09:20 PM
scheetz93's Avatar
thanks for you help!!!
Old 10-19-2005, 09:27 PM
I bet it looks better with the covers off. JMO
Old 10-19-2005, 09:32 PM
scheetz93's Avatar
it would put that would mean i would have to make a set of buckets for a sealed round headlight
Hard piping air lines ... help (LONG) candygram Garage - Tools 19 10-18-2005 06:23 PM
detonation resistance, short or long rods? Old School Nut Engine 34 12-31-2004 12:23 AM
How long will lacquer primer last? ChrisMiddleron Body - Exterior 2 06-17-2004 05:35 PM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 09:29 AM
Sanding, Dry vs Wet, Air vs Elec Bluepen Body - Exterior 3 05-12-2003 03:45 PM
