How Long Should PS V-belt Last? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2013, 01:53 PM
The PS belt on my engine is 6 years old with 17,400 miles driven on it, and squeals at startup. It is a 44.5 inch belt and I can't tighten it any more. I estimate I have moved the reservoir about 1/8 to 1/4 inch over that time frame to keep it tight enough to not squeal.
The next shorter belt is 44.0 inches and I might not be able to get it over the pulley system.
Do these belts stretch or wear down with time such that it just needs to be replaced with the same size belt?
John
Old 07-24-2013, 02:26 PM
cal1320's Avatar
At 6 years old, you should replace the belt. Even though it only has 17K miles, the rubber in the belt hardens as the belt ages.
Old 07-24-2013, 02:31 PM
RWENUTS's Avatar
Does the belt sit all the way in the pulley groove?
THere are different belt widths and pitches.
Old 07-24-2013, 03:54 PM
Banned
New belt , not smaller and you should be fine. I change mine out every 2 years no matter what. and the old one goes in the trunk with a wipe down of silicone. just for a spare.
Old 07-24-2013, 04:21 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I had the same problem ,mime had a 44.5 x15mm wide ,I switched to a 44 x 13 wide it sits deeper in pulley to stop squeal so I has to be slightly shorter.
Old 07-24-2013, 07:39 PM
The top of the belt is slightly below the top of the pulley rim. It definitely does not seat in the bottom of the groove.
John
Old 07-25-2013, 07:26 PM
Replaced belt with exactly the same belt today and it is much tighter. Apparently, belts either wear down or stretch.
John
HOW TIGHT DOES A Grilmer Belt Drive BELT SUPPOSE TO BE the82elco Engine 7 12-23-2012 02:41 PM
serpentine belt & water pump belt coldfreshwater Engine 3 12-19-2012 07:03 AM
How long V-belt? staleg Engine 12 05-08-2012 10:51 PM
V-belt idler pulley ? belt rides backside JeepsAreBuilt Engine 4 05-09-2010 10:01 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 07:56 PM
