LinkBack | Thread Tools |
How long is too long to wait after sanding poly primer before i can spray a 2k?
As the title says, how long can i leave the sanded polyester primer before i spray my 2k on it? How long is too long because i read somewhere that it should be topcoated within a reasonable amount of time but that wasn't clear. The weather just dropped down past 55 degrees so i need to wait to 2k prime in my garage.
Thanks Chris |
Bob's right,Your good to go within a "reasonable" time frame.
Once the poly is on,it's sealed and unless you been spraying WD-40 or such,You should be good to go. You can always do a good wipe down with grease & wax remover to be on the safe side if you wondering. |
| Maaco vs. At-Home Paint Job | nightrain_rod | Body - Exterior | 127 | 08-26-2012 03:07 AM |
| Barry K / Martinsr :How long between wet sanding and painting? | bloverby | Body - Exterior | 7 | 11-27-2005 08:39 AM |
| Lacquer primer question | badriand | Body - Exterior | 18 | 07-23-2004 03:08 PM |
| 2k Primer scraping off? Need help | misteryu | Body - Exterior | 1 | 07-17-2004 04:55 AM |
| How long will lacquer primer last? | ChrisMiddleron | Body - Exterior | 2 | 06-17-2004 05:35 PM |
