how long will the 7.5 10 bolt hold up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2011, 08:00 PM
I just got a nova that has a 7.5 10 bolt with 3.73 gears and locker in it. My 383 has roughly 425-450 hp at the crank, th350 and 3500 stall. I know it s a pathetic rearend but it was in the car when i got it, how long will it last?
Old 11-04-2011, 10:52 PM
SSedan64's Avatar
How long it will last is up to you. Be gentle, no Slicks or sticky Tracks & it'll last a long time.
Old 11-05-2011, 03:06 PM
gerbsinmd's Avatar
Yup, it'll last right up until you get traction. I've run a 383 in a Malibu for 5 years, high 12s low 13s, 1.9x 60' times with no issues. But no slicks either and leave the line just above idle. No issues with it yet, but I have seen guys try to run the same rear in a lighter car with slicks and a trans brake and it didn't last 2 trips to the strip.
Old 11-05-2011, 03:09 PM
T-Bucket, Corvette, Mustang
You could help the 7.5 by installing a differential girdle.
Old 11-05-2011, 06:33 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
are you sure its a 7.5 and not a 8.5 cause i didnt think 7.5 came in novas just the 8.5 but like they said should be fine without slicks i have a 7.5 in my monte with a 385 stroker with about 500 hp and had no issues and been that way for about 5 years
Old 11-05-2011, 11:49 PM
SSedan64's Avatar
Some Nova's started getting the 7.5" 10-Bolt in 76 for 6cyl. & 305V8 along with that wonderful TH200 Trans , other Yrs. only the 6cyl. got the 7.5" Rear. 72-75 was 8.5" only.
More Info>> http://www.novaresource.org/axle.htm
Over the Yrs. GM offered the Nova with about every size Rear available, 7.5", 8.2" 8.5" & 8.875"
12-Bolt/8.875" Rear looks like the 8.2" Cover but, with 12 retaining bolts.
Name:	10 Bolt Rear ID.jpg
Old 11-06-2011, 08:22 AM
84 stroked ss
ok thanks i learn something new all the time
Old 11-06-2011, 10:55 AM
I was wrong, I have an 8.2" rear. How good is this 10 bolt? Im running a 275/50 mickey thompson e/t street on mono leaf springs. Its only been down the track once and ran a 13.03 @103 untuned, I was happy with that. Thank you for the link and help.
How long does your pump hold pressure? 001mustang Engine 9 12-30-2009 11:32 PM
Short and long shaft TH350's.... and extra long too? 383ram Transmission - Rearend 11 02-27-2009 05:08 AM
How long is too long to wait after sanding poly primer before i can spray a 2k? misteryu Body - Exterior 2 03-17-2006 09:49 PM
A long long time ago, in a galaxy far far away.... WakBordr7387 Hotrodders' Lounge 2 05-19-2005 03:07 PM
Can a 10 bolt hold up RObs71Nova Transmission - Rearend 19 11-05-2004 08:20 PM
