How long is your driveshaft? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2006, 12:11 AM
TheCarMan
Driveshaft that is..............
I need to take a poll.
I am 2/3's the way through swapping a complete '56 chev driveline into my coupe. (265 powerpack, cast iron 'glide and stock rear...all fresh)
The problem is... the P.O. kept the driveshaft for his '56.
I measured 57"-60"....depending where I position the motor mounts. I can't weld them until I figure out a driveshaft.
I have the yoke......so I just need the shaft.
I was informed that a 62-67 Nova driveshaft, 55-57 chevy driveshaft or 64-67 malibu shft will fit.
Does anyone have a driveshaft out of their 55-57 chev..... that they can measure?
Or '62-67 nova? Maybe something else?
I would prefer to stay old chevrolet for U-joint compatability (local parts store doesn't carry bastard u-joints).
Thanks in advance.
And, YES...........I am too cheap to go have one made.
Name:	51 chev1.jpg
ID:	12856   Click image for larger version
Name:	51 chevhayzeebw.jpg
Old 06-23-2006, 06:30 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
I would just get the Eng mounted where it needs to be then measure and find a drive shaft a little longer and have it cut down and balanced that is the best way to get it all right!
Thanks in advance.
Success is getting what you want but happyness is liking what you get.
New Driveshaft Noise bjam2 Transmission - Rearend 6 08-26-2006 11:18 AM
driveshaft swap william27103 Transmission - Rearend 4 10-29-2004 07:20 AM
Driveshaft database? fat50 Transmission - Rearend 5 08-30-2004 03:42 PM
wrong driveshaft length? darom Transmission - Rearend 16 03-23-2004 07:59 PM
Driveshaft measurement 71gtx Transmission - Rearend 6 01-11-2004 11:00 AM
