How LOW compression ratio can be? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2009, 07:31 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm working a set of vette heads to install on my SUPERCHARGED 350 SBC
the blower is a 144 B&M that pumps 8 psi with the current 882 head, I guess the high boost comes partially from the restrictive heads, it also has the smallest driven pulley that B&M had made for the smaller 305 engine.
it is a STREET engine and will burn pump gas
I want to extract as much power out of it and with the current heads I have to limit timing a lot because it pings like crazy so actually does not make much power.
I've seen racing turbo engines with compression ratios as low as 5.5:1 but they are racing engines, what would happen if I go that low on a street engine? will it be a real dog when there is little or no boost?
I used to have a '62 Land Rover that had 7.1:1 compression ratio and was a very smooth and torquey engine.
My plans are carving the heads a lot unshrouding the valves, this will let them breathe very well and will reduce compression at the same time.
please give me your opinions, thanks.
Augusto.
Old 01-28-2009, 07:53 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Eight pounds of boost isn't excessive, combined with a cr of 8:1 you're fine with pump gas.
Semper Fi
Old 01-28-2009, 08:09 PM
Augusto's Avatar
but pings like crazy and I have to run very low ignition timing to compensate, our gasoline is not that good, I should of say this first, I was thinking of installing water injection but I think I will be better with a lower compression that will allow me to pump more air into the cylinders and make more power, in other words make the engine think it's bigger.
Augusto.
Compression ratio dubie Engine 3 06-25-2004 08:50 AM
how to keep low compression 67bird Engine 14 02-08-2004 07:10 PM
Compression Ratio BlownBirdy Engine 3 12-18-2003 08:46 PM
compression ratio for a 350 sbc??? classic_chevy_guy Engine 6 10-27-2003 11:44 AM
how to figure out compression ratio? Trav Engine 5 08-05-2003 09:09 PM
