How Low To Go? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-23-2012, 06:20 AM
poncho62's Avatar
Wiki Edits: 5
Originally Posted by deadbodyman View Post
A 4x4 is actually 3 1/2' x 3 1/2" some people shouldnt be messing around with cutting tools and tape measures anyway
Depends if it is rough cut or finished cut..........Lots of barn builders use rough cut.
Ontario Rodders
  #17 (permalink)
Old 10-23-2012, 06:26 AM
deadbodyman's Avatar
Wiki Edits: 11
LOL ,true enough...
  #18 (permalink)
Old 10-23-2012, 12:43 PM
how low to go?
As a guy who does lots of woodworking I am aware of the dimensions of the lumber yard bought 4x4. With a table saw there are lots of ways to make real 4"x4" blocks. I think they will suffice and 2" dropped spindles will spare the large expense of airbags. Good shocks, and healthy IFS will provide a nice ride.
Thanks for the tips though.
  #19 (permalink)
Old 10-23-2012, 01:43 PM
1971BB427's Avatar
One problem with a set clearance to any obstruction is where that lowest point is. If it's inline with the front or rear wheels it will rarely cause an issue, but if the lowest point is halfway between front and rear wheels it will be a constant problem. As will a low point that is close to the front or rear bumpers. The farther you get from the wheels, the more likely the low point will scrape.
  #20 (permalink)
Old 10-23-2012, 01:59 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
A 4x4 is actually 3 1/2' x 3 1/2" some people shouldnt be messing around with cutting tools and tape measures anyway.
4" is a good (what we call ) ride hight. and there is no better ride than a car on air bags..plain and simple
You are correct, but when I chose that piece of 4x4, many years ago, 4x4's measured 4x4 and 2x4's measured 2x4. Younguns may not know that there was a time in this country when everything actually was what it was supposed to be.
  #21 (permalink)
Old 10-23-2012, 07:04 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
A lot of fellas don't care about scrub line issues, but since it is being discussed, consider this:
The 4 x 4 method doesn't take into account tire sidewall height. Let's say your rear shock brackets are the lowest part of the rear suspension and they are 3-1/2" off the ground and are mounted close to the tires. Let's also say you have a 5" tall sidewall on your rear tires. If your rear tire goes flat your shock brackets are now plowing into the asphalt.
The air bag anology of "adding more air" is a faulted one... what if you loose an air line?
To be safe the other scenario you have to look at is to assume the vehicle is sitting on the snubbers on all four corners, assuming the vehicle even has suspension stubbers.
Study the scrub line photos Sedanbob linked to, I attached them to this post also. They help to define what the issues can be.
Hope this helps.
Name:	Scrub Line Front To Rear.jpg
ID:	68560   Click image for larger version
Name:	Scrub Line Front.jpg
ID:	68561   Click image for larger version
Name:	Scrub Line Rear.jpg
  #22 (permalink)
Old 10-23-2012, 10:52 PM
how low to go?
I'm getting a real education from you guys and I appreciate it. I'll make those measurements in the pictures tomorrow and see what I get. I feel pretty good about how mine sits, safety-wise, but just to be sure I'll take these extra steps.
  #23 (permalink)
Old 10-24-2012, 09:25 PM
bentwings's Avatar
bentwings
4 inches minimum seems like a good number.
I hit a dead racoon and wiped out my air dam which is 2 inches and it missed the front crossmember at 4 inches.
Mild RV Cam; low vacuum; low brake pedal knightline Engine 2 08-25-2012 09:57 AM
Low volume Low pressure paint gun 35olds Body - Exterior 27 06-28-2006 06:48 PM
Be aware of Low Cost, Low Quality Aluminum Heads Larry3 Engine 17 04-21-2006 07:05 AM
Small headers to improve low end torque with low CR?? Malibu73 Engine 2 10-04-2005 05:03 PM
Can a low low battery, cause car to bog? Rubberman2003 Electrical 17 08-31-2003 08:19 PM
