How Low To Go? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2012, 09:46 PM
How Low To Go?
What is considered a safe height measuring ground to lowest point on the front crossmember? I want to drop my coupe some more, but if I use 2" dropped spindles, my clearance will be 4" to the ground. Too low to be safe or OK?
Thanks
Old 10-17-2012, 10:21 PM
vinniekq2's Avatar
check locan speed bumps at the grocery store
Old 10-17-2012, 10:24 PM
how low
I can do that.
Old 10-18-2012, 02:09 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
In wa state the rule is no lower than the bottom of the rim of the wheel so the minimum ride height is the height of the tire sidewall..hope this helps..at that height you will bottom on some of the higher speed bumps and scrape on some drive entrances..
Sam
Old 10-18-2012, 10:34 AM
sedanbob's Avatar
The NSRA uses the term 'scrub line', saying nothing should be lower than that. Here is a link to three diagrams describing scrub line: Scrub Line Hope this helps.
Old 10-18-2012, 11:37 AM
how lo to go
thanks fellas for your thoughts. appreciate it.
Old 10-18-2012, 06:41 PM
how low to go?
I went to a website to learn about the scrub line. Here is what I did. Correct me if I am wrong. I measured the lowest point of the IFS cross member to the ground - 6". I then measured the bottom of the rim of the wheel to the
ground-3 1/2 ". The difference is 2 1/2". I then subtracted the 2" for dropped spindles giving me a 1/2" clearance. Is this amount of clearance enough? I do want the low look but I also want to be safe.
Old 10-19-2012, 05:26 AM
Last journal entry: 27
my 27 has 6" of clearance and i scrape on some speed bumps.
Old 10-19-2012, 01:14 PM
how low to go?
you must have some humungus speed bumps where you live. I think your scrub line would be much lower than 6". with the 2" dropped spindles I would actually have 4" of clearance from the ground to crossmember with fully inflated tires. The 1/2" clearance I mentioned is the amount of clearance if rim sat on the ground, which isn't going to happen. Mt question should have been, is 4" enough clearance? Sounds like it would be marginal. I'll think on this some more.
Old 10-22-2012, 07:39 AM
deadbodyman's Avatar
Wiki Edits: 11
I used air bags (springs) when I need more hight I just air them up a little,My old coupe is pretty low,with all the air out its 1/2" off the ground .its been channeled about 6"...The bags are nice i like them
Old 10-22-2012, 12:12 PM
techinspector1's Avatar
Wiki Edits: 326
Many years ago, this question was on my mind too, so I thought about it for a while and determined that the lowest OEM automobile would be the Corvette. I went up to the local Chevy dealer and crawled as close to under as I could get to push a tape measure up under the car all around. I found that nothing was any lower than 4" from the ground. I reasoned that if the General had it figured at 4", that would work for anything I would build. Down through the years, I have kept a 4" x 4" block of wood in the garage. I slide it around under the car as I'm building and everything has worked out well for me.
Slamming a car looks nearly as stupid to me as a chopped top. Monkey see, monkey do.
Old 10-22-2012, 01:40 PM
how low to go?
Thanks for your info. I have actually thought of doing what you did with the corvette, but hadn't got around to it. 4" drop will look great on my coupe and if too low I can always change the spindles back. The speed bumps in our local area are in the 2" range, so with some slowing down I think they can be maneuvered pretty well. I don't like the slammed or chopped look either, but I do like a nice rake on an old ford coupe.
Thanks again for your common sense idea. I am going to try again to load a couple of pics of my coupe on this site. Tried over the weekend, but did something wrong I guess as I don't find them now.
Old 10-22-2012, 01:45 PM
sedanbob's Avatar
The idea behind the scrub line is that if a tire goes completely flat (you're sitting on the rim) nothing underneath scrapes the ground. Sounds like yours will just clear (by that 1/2").
Old 10-22-2012, 01:53 PM
how low to o
That is correct. 1/2"
Old 10-23-2012, 07:12 AM
Wiki Edits: 11
A 4x4 is actually 3 1/2' x 3 1/2" some people shouldnt be messing around with cutting tools and tape measures anyway.
4" is a good (what we call ) ride hight. and there is no better ride than a car on air bags..plain and simple
Mild RV Cam; low vacuum; low brake pedal knightline Engine 2 08-25-2012 10:57 AM
Low volume Low pressure paint gun 35olds Body - Exterior 27 06-28-2006 07:48 PM
Be aware of Low Cost, Low Quality Aluminum Heads Larry3 Engine 17 04-21-2006 08:05 AM
Small headers to improve low end torque with low CR?? Malibu73 Engine 2 10-04-2005 06:03 PM
Can a low low battery, cause car to bog? Rubberman2003 Electrical 17 08-31-2003 09:19 PM
