How Low RPM Can a Dyno Read? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2008, 09:07 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
How low can they go? Typically you see pulls from 2500-3000 and up. Can they effectively measure below that?
Old 07-23-2011, 05:57 AM
v8hed's Avatar
AK427
Found this thread via a Google search and would like to bump it up...
My engine/dyno guy said he couldn't load my engine up much below 2,500rpm because the engine dyno (Superflow) wouldn't be able to hold the torque. He said this was because the water brake the dyno uses wouldn't be shifting sufficient volume of water to hold the motor.
On another forum I post on, there's a guy arguing that this is rubbish and the only reason a dyno can't go lower on a particular motor is because the MOTOR doesn't develop enough torque to fully load-up the dyno.
Who is right? Please explain.
Old 07-23-2011, 08:36 AM
This article doesn't answer your question, but it does provide a fairly good description of how the water brake and other dyno's work.
http://www.dyno-dynamometer.com/how_dyno_works.htm
Bruce
Old 07-24-2011, 05:17 PM
Zero rpm.
That is how they are calibrated.
For example, take a ten foot arm, bolt it to the frame of the load absorber part of the dyno, hang a ten pound weight off the end, and the dyno torque reading is then adjusted to read exactly 100 Ft/lb.
You can calibrate it for any torque reading by using a different arm length or weight, but the principle still applies.
Some types of load absorbers such as eddy current or water brake cannot hold very high torque at very low rpm.
The dyno itself will read torque an Hp accurately right down to zero speed.
You just may not be able to hold the engine speed down at very low rpm, even at full load.
Something like a big turbo diesel truck motor can make a whole bunch of torque down at 1,000 rpm, and some dynos just cannot put enough load on the motor at that very low speed to hold the engine back at full throttle.
Old 07-24-2011, 11:16 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I'm thinking it has to do with the usable powerband of the engine. Since many gas engines don't start making substantial power below 2000-2500 rpm is there really any reason to measure torque that low? This is especially the case in most performance engines. I've seen semi truck engines that max out at 2100-2200 rpm on dynos.
I don't think a given engine should fully load the dyno? If it did that then you couldn't put a more powerful engine on that same dyno. The dyno needs to fully load the engine. At least that's my take on it.
Old 07-24-2011, 11:24 PM
Yup spot on .
Old 07-25-2011, 05:16 AM
v8hed's Avatar
AK427
This was the reason given to me by my engine/dyno guy when we were dynoing my 383... I was curious to see torque numbers below 2,500rpm, but he said the dyno wouldn't be able to hold the engine that low. Torque at 2,500 was 400lbft. A guy on another forum I post on has said that's rubbish and the only reason my motor couldn't be measured below 2,500 is because it's over-cammed and doesn't develop enough torque to load-up the dyno. Well, I don't think it's over-cammed if it's developing 400lbft at 2,500.
new383ci dyno hp is low roy383ci Engine 9 08-16-2006 02:47 PM
Low rpm miss 1969NovaSS Hotrodding Basics 3 07-24-2006 05:42 AM
rattling at low or high rpm IROC-russ Transmission - Rearend 4 09-15-2004 11:50 PM
MY SBC 400 DYNO Yesterday WOW, WOW, WOW DTL504 Engine 9 07-03-2004 12:18 AM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
