How low should i go - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2012, 05:21 PM
How low should i go
I got a 65 C10 wanting to drop it but unsure seen i never lowered a C10.I would like it to be a driver not a center piece though looks mean alot.Realy dont know what way is best springs,spindles or bags?
Old 07-11-2012, 07:10 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Here are my thoughts, up for cussin' and discussin':
These trucks, 60-66, have low hanging front crossmembers and lower control arms. You can do a 3" front drop with springs. If you then use 2" drop spindles the lower control arms will really be too low due to scrub line issues for a realistically safe daily driver. A lot of olks are using aftermarket front crossmembers which solve some of these issues, but are pricey.
As for the rear you can go with 5" drop springs, anything more will require notching the frame. And if you use lowering blocks in the rear, anything more than 2" is also bad, again due to scrub line issues.
A scrub line issue basically means that if a tire goes flat that suspension components or the frame will rub on the ground. If that happens you may well be at the mercy of the god's of speed as to if you live or die.
Here's a photo of my '65. It has a 3" / 5" spring drop, stock front spindles, no rear lowering blocks, no rear notch.
low end torque and low compression blowboatjunky Engine 13 04-27-2011 09:10 AM
Low volume Low pressure paint gun 35olds Body - Exterior 27 06-28-2006 06:48 PM
Be aware of Low Cost, Low Quality Aluminum Heads Larry3 Engine 17 04-21-2006 07:05 AM
Small headers to improve low end torque with low CR?? Malibu73 Engine 2 10-04-2005 05:03 PM
Can a low low battery, cause car to bog? Rubberman2003 Electrical 17 08-31-2003 08:19 PM
