How to make 4L60e work on 350 sbc that had 700r4 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 08:46 PM
A Todo Madre o Un Desmadre
Last journal entry: 700r4 rebuild
i know that this post is old and prob. a stupid question but wat would it take to have a 4L60e work with a 350 small block that had a 700r4 transmission
Old 11-12-2012, 09:49 PM
SSedan64's Avatar
You'll need to install a Manual Shift Kit, Manual Controller or for automatic shifts a seperate Trans Controller.
You'll also need to sort out the Speedo, cable or electronic operation.
TransGo | 4L60E, 4L65E, 4L70E and 4L75E: 4L60E-3
Rossler Transmissions bottom of Pg.
4L80E Components
parts needed to make 700r4 work in 95 4x4 benshelton383 Transmission - Rearend 16 12-01-2010 09:34 AM
swapped engine, now 4l60e trans wont work. heavyfooted Transmission - Rearend 0 05-22-2010 05:32 PM
carburater and 700r4 how to make work together? fastcamaro88 Transmission - Rearend 4 09-21-2007 10:55 PM
HOW TO MAKE 700R ELECTRONIC TRANS WORK IN 59 Chevy pick up hexx Transmission - Rearend 4 02-11-2007 01:31 PM
will 4l60e work in my 89 silverado? It has a 700r4. mojokimble Transmission - Rearend 2 04-21-2006 08:16 PM
