lol just build a 383 @ 10.5:1 and add the trick flow 500hp BOLT ON KIT
so much easier for a street/strip machine or just a 12.5:1 355 and basically the same parts with a custom grind cam, alot more rev's and youll need better quality parts because youll make that 500hp alot higher in the RPM range.... its not that hard its just more expensive if you want it to last...think of it this way, the money youll save on valve springs you could just build a stroker, because reliable 500hp n/a from a 355 is gonna be solid roller cam, expensive springs/rev kit etc... Im talking real 500hp not desktop dyno kinda thing because although they are a valuable tool to some real world 500 hp is just a lil differnt...anyone who ays otherwise will have to prove thier "500" hp desktop dyno build on the track where MPH and E.T> do not lie.... |
There are a LOT of 500hp 350's out there. This isn't anything new, and it doesn't need to be as radical as people are describing, though it is expensive.
You can get there with a hydraulic roller cam, flat top pistons, 200-220cc heads, carb or efi, nothing too extreme. Realistically you're probably looking at a power peak around 6500 rpm, which is higher than most street driven cars but not too unusual. A higher stall would be needed as already noted but a manual trans would probably be best. |
Why saddle yourself with the stock block? I have never, will never understand this. Get a Dart Little M or an SHP block. Throw down at least 396 cid. up to say 427cid. This gives you room to grow (I believe up to 454)
Save the numbers matching stuff for garage art until you sell the car. If you chuck a rod through your numbers matching block....good luck. Paint your little M block orange and 99% of people would never notice. Yes its more money; the motor will have better manners, make more power, be stronger and give you the peace of mind that its not going to come apart at the seams. Good seasoned blocks with minimal coreshift are getting hard to find these days; and you want to avoid the thinner castings. Or you could find a boatyard and get a 502 mercruiser motor; change the cam and intake and get awfully close to your goal |
This can be and has been done with a stock block, stock crank, even stock rods if you so choose. You can use stock lifters, stock lt1 pistons, and if you're really good a highly modified set of stock heads and intake. Sure using all of that takes a lot of time and skill but if you have it it saves money. If you don't have time and skill it'll be expensive. |
What my suggestion entails is perhaps getting another grand together is cheaper than Murphy's law at the 500hp level. Just my preference; as you said, a good condition stock block can certainly take 500hp, but you have much less margin to play with. Last edited by AutoGear; 08-06-2012 at 09:45 AM. |
I'd rather spend the extra money in the rotating assembly than an aftermarket block. Blocks do occasionally break, but it's usually a failure in a rod or the crank that results in the breakage. I'd find a decent rebuilder 4 bolt 350 and check the bosses to make sure there's no excess core shift, then build from there. Around my area a good rebuildable 350 4 bolt short block will go for $150-$250, {bare blocks even cheaper) and the savings can go towards a forged crank and other things that can fail sooner than the block.
do a search on this forum... this question gets asked about every other week. Then come back with a better list of intended use, parts, car, budget and we can better help you get parts lined up. Right now its kinda like shooting from the hip.
you guys mention an extra grand laying around! The DART SHP block is 1600.00 (not including the 100.00+ s/h) and the DART little M is like 2500.00 (again not including s/h). Unless you are planning on running over 600hp or planing on running a 3.875+" stroke then I dont see the point. for the extra money you spent on the block i could tear down the motor, buy another block, have it machined and likely buy a few rods or the crank to replace the one that broke. Im all about saving the extra cash to make sure you do it right, but i dont see where an aftermarket block is needed.
to the OP, a 350 making 500hp NA isn't too hard, but one making 500hp NA on 93 or less octane is. it will want to turn some rpm, so a decent forged rot assy will be needed (IMO) you will want to push the limits with compression, say 11-11.5:1 with alm heads that have around 210-215cc intake runners, spend the extra cash and have them cleaned up, 112LSA hyd cam with around 245° @ .050 and .575" lift, use 1.6 rockers to bump you over the .600" lift mark. use a single plane intake like the vic jr, and a 750 double pumper. matched in a 3500lb car with a 3spd (th400-350), 3600-4000 stall and 4.10's to 4.56's. It wont be as much fun on the street as it will on the track, but you should be able to get it to run on 93 octane. |
I agree with vinnie what is your budget and what is your app.??? what year and type of block are you starting with????? also how do you want too use it , daily driver, weekend warrior, or just a cruser???
Even some of the bowtie blocks can be built with 400 or more cubes. |
| Trying to get 350 to 500 hp out of a chevy 4.3L V6 | AutoTech24 | Engine | 17 | 08-24-2010 09:18 AM |
| chevy 350 horsepower help | badazzz28 | Hotrodding Basics | 2 | 01-16-2009 05:52 PM |
| trying to get 500+ horsepower | llee235 | Engine | 2 | 07-23-2004 01:56 PM |
| how to make a 327 push about 300 to 350 horsepower | engine-rookie | Engine | 2 | 07-18-2003 12:00 PM |
| 350 chevy horsepower | yannick | Engine | 3 | 03-01-2003 09:08 PM |
