HOW TO MAKE 700R ELECTRONIC TRANS WORK IN 59 Chevy pick up - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2007, 06:51 AM
I have a 59 chevy pick up and im puting a 700r electric trans on it and want to kno whow i can make the trans work and the orverdrive do i need the comp its out of a 86 camero
Old 02-11-2007, 07:20 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
The computer is not needed to make the trans go into overdrive and have the converter lockup. There is a pretty easy electrical connection that needs to be done though, company's like B&M or TCI have a kit to make it work. You can use the search tab at the top of the page to find additional info. This has been discussed in detail before, try something like "converter lockup".
You will also need to hook up the TV cable, that info can also be found by using the search tab.
Old 02-11-2007, 09:48 AM
So how would i do it to make it work is there a site or a post that tells me everything
Old 02-11-2007, 11:59 AM
DOUBLEDICK's Avatar
I have a 700r4 in my 58.My valve body is set up to lock the converter when it goes into 4th gear.I have over 500hp so this is ok for me.They make a vacuum valve that goes in the manifold and it locks the converter when cruising in overdrive.Most people use a toggle switch and manually lock the converter when on the highway and unlock it in town.I had my transmission built by Expert Transmission in Henderson Nevada.You can get the parts you need from jegs.If you look through the old posts in the transmission section you should find this information.If you go to the hotrodders lounge look up the post"55 to 59 chevy truck owners"you will find that there are allot of guys with these trucks that can help you with this project.
Old 02-11-2007, 02:31 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
http://www.bowtieoverdrives.com/cata...AT&CATID=OA1A3
http://www.tvmadeez.com/article/index.html
http://purplesagetradingpost.com/sum.../techinfo.html
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 12:06 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
454bbc with t 400 trans 19471/2ton chevy pick up timbro 42 Engine 8 03-11-2009 08:03 PM
Chevy SM465 Man 4 SPD Trans? swoo55 Transmission - Rearend 0 10-26-2003 05:07 PM
Buick V8 to Chevy trans Smonska Transmission - Rearend 7 04-12-2003 04:58 AM
