How to Make Caliper Mounting Plates? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2011, 11:24 PM
So, just how does one go about making caliper brackets?
I ask since I'm trying to make caliper mounting brackets/plates for a rear disc conversion using 3/8" plate and spacers on an 8" rear using Lincoln LSC calipers like the type Currie makes HERE .
Does the rotor have to sit in the middle of the unloaded space between the caliper pads?
Old 02-15-2011, 06:51 AM
31 five window
Last journal entry: grill and rear end
The pad opposite the piston should be just touching the rotor. Other than that make sure the bleed screw is as straight up as possible to let all the air out.I also recommend grade 8 fasteners.
Do Clutch Plates and Pressure Plates Have to be the Same Diameter? mrwumper Transmission - Rearend 3 03-30-2009 01:43 AM
Which caliper? Tomard Garage - Tools 8 10-14-2008 11:44 AM
Cam wear plates/thrust plates jakejake1966 Engine 3 04-12-2006 04:54 AM
engine mounting plates 2Cammer Hotrodding Basics 6 12-20-2005 06:53 AM
Caliper Que. HELP!!! 39chevy Suspension - Brakes - Steering 6 06-03-2004 07:01 PM
