How to Make a good Pattern From a Bad Original - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2009, 10:46 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Occasionally I get a seat to repair that is so screwed up that it's hard to make a pattern from. Here is the perfect example, and the problem is compounded by the fact that the left side of the seat cover is not the same as the right side, and the seat foam has been destroyed as well. Usually, I can make my pattern from the passenger seat, but this time I only have the driver's seat. Here's how to get around the problem. I spray a piece of pattern chipboard and the top of the vinyl piece I want to copy with foam to foam glue. (The vinyl piece has had the 1/4" foam backing removed from it. I use my 12" foam saw to do this just like removing the skin of a fish.) Then I lay the old vinyl piece loosely upside down on the chipboard. From there, I position the old piece until I think it looks correct and then press down firmly to hold the vinyl in place on the chipboard. How do I know how long to make the piece that is screwed up the most? I measured what that piece is sewed to to get it's length. I don't use contact adhesive because I want to be able to re-position the vinyl if I need to and the foam to foam glue doesn't hold as tightly as contact adhesive. After that, I mark the position notches, and cut the chipboard around the perimeter of the vinyl. Then I peel off the vinyl, make cuts in the chipboard where the position notches are and mark the notches on the other side of the pattern. Now I have my patterns and I know that the side without the glue goes up. I let the glue dry before I use the pattern so I don't have glue to remove from the new vinyl.
ID:	38150   Click image for larger version
ID:	38151   Click image for larger version
ID:	38152   Click image for larger version
Old 05-18-2009, 01:36 PM
JrJohnston's Avatar
Dan it looks like they got their monies worth out of that chvey truck seat...LOL
Done too many of them also.
Old 05-19-2009, 11:15 AM
do you need to account for shrinkage of the original or is that not a factor?.....Steve
Old 05-23-2009, 12:04 PM
Wiki Edits: 22
The vinyl isn't going to shrink enough or stretch enough to worry about. Remember, you need to measure what the pieces are going to be sewn to and adjust the patterns accordingly.
Old 05-25-2009, 12:50 PM
where would i find foam to foam Glue? Any other glue I could use?
Old 05-25-2009, 02:40 PM
Wiki Edits: 22
You can find adhesives HERE Almost any adhesive will work as long as it can hold the old vinyl from the seat cover to the chipboard long enough to create the new pattern. Even 3-M 74 or 3-M 77 would work, just don't use them for anything else.
Old 05-25-2009, 10:31 PM
thank you very much
Car cover good idea or bad? oldred Body - Exterior 26 05-02-2013 07:25 PM
How to make a good hp motor with a 302 and a 327 Highball125 Hotrodders' Lounge 5 09-24-2006 12:01 PM
Bowtie Overdrives, good or bad sotxpanrider Transmission - Rearend 4 05-28-2006 11:55 AM
305, good, bad,? Geargrinder65 Engine 19 05-04-2006 12:32 PM
Good Grounding can make a difference ep33510 Electrical 2 12-07-2005 07:42 PM
