How to make headers with side pipes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2007, 06:59 PM
1930u's Avatar
Last journal entry: 1930u more fuel line plumbing
Hi all,
I'm thinking about trying to make a set of headers. How do they do the 360 degree welds where the pimary tubes enter the collectors?
Thanks!
Old 11-07-2007, 07:25 PM
Vortech 4.3's Avatar
jack of all trades
looks to me, like they weld the inside, where the 4 pipes touch each other. then put the collector on and weld the outside.
Old 11-07-2007, 07:50 PM
You could make a diamond plate for the center and weld around the outsides.
Shane
Old 11-08-2007, 10:04 AM
cboy's Avatar
Last journal entry: Finished
I just welded up a set of headers (side pipes should be done this weekend) and have some pics and text in my cboy-two journal here http://www.hotrodders.com/forum/jour...81&action=view
Vortech is correct that the header tubes are welded INSIDE the flanges, not around the outside. However, to put your kit together, you will probably have to tack weld the tubes on the outside and then grind off those welds once everything is done. (see photos below)
Also, Shane is correct that you need to weld a center tab where all the tubes meet up at the collector (see arrow in photo below). Also, you need to weld the tubes to each other as far back as the collector is going to slip on (probably makes more sense in the pictures below).
This shot shows the inside of the flange with the tube welded in a ground down a bit.
This shot shows the diamond shaped piece welded in the center of where the tubes meet up (lower arrow) and the upper arrow shows the pipes welded together as far back as the collector tube will slip over.
This one shows the collector slipped in place. I haven't welded in on yet (will do so after making the side pipes) but it will be welded all around each tube and the welds will be continued down between the tubes (arrow) to where the weld was made in the prior photo (the weld is just visible between the pipes).
And this one just shows the grind marks on the flange and pipes after cutting off the tack welds used during the fabrication process.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 11-09-2007, 06:47 PM
1930u's Avatar
Man you guys are awsome thank I can do this!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Headers are done 78 monte Engine 10 09-04-2004 02:52 AM
Replacing the headers on my 72 Nova 72Nova383 Engine 3 09-01-2004 09:07 AM
opinions please on side pipes helrazr3 Hotrodders' Lounge 46 06-28-2004 09:15 AM
