Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to make a rearend jig.
Old 07-28-2011, 04:34 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by zildjian4life218
I already started sketching out the base of the jig. I'm gonna use the alignment jig to hold the axle center on the bracket jig. Now I just gotta get ahold of some steel. Do you guys use any special steel for the alignment jig bar. I figured a 1" round piece of steel should work but not sure if it has to be any special grade steel.
Mine is just a piece of 1" round bar stock called TGAP(Turned, Ground, and Polished)that I got off of the leftovers rack at work, but plain old 1" round cold rolled bar stock would be just fine.
